Firestore Conform Problems and Woes!
grimrebes
This is related to another post of mine in the FCP forum. I realize the Firestore FS-100 is less relevant to many these days because of the rapidly dropping prices in P2 media, but figuring a great number of students might be using them soon, that many people out there may still be using them for long long form interviews, and well, just to let people know...
I am in the Middle East. I've been working on a few projects, and an editor/friend of mine in LA saw some footage I shot a few months back and wants to work on it. The HD footage is too big to post on an FTP, but DV footage would be fine. However, conforming has proved to be a slight problem.
Why?
The footage is DVCProHD 720p24pN. The DV25 files we've made from them follow the timecode sort of. If I set the export settings in compressor to DV25 at the current frame rate, the hour and minute TC embed do not change. But the frame numbers do. The DVCPro master clip skips frame numbers 3, 8, 13, 18, 23, and 28 when playing back in a 23.98 sequence editing timebase. Why? I recorded from an HPX170 onto a Firestore, and the FS-100 records a 720p stream with a pulldown removing the duplicated frames to record the native 24p a second.
The problem is the DV25 clips do not have this problem. They play out with frame numbers :00 to :23 with no issue. No skipping, nothing odd. The TC matches except for the variations in the embedded frame numbers between seconds.
Unless I can figure this out, this presents an issue for conforming the online edit.
Regardless of the solution, be aware that the FS-100, when recording that 720p stream over the firewire and removes duplicated frames, does not adjust the timecode accordingly.
If this is something people are well aware of, then forgive me, because I read up on this beast (the FS-100) and have used it thoroughly, assumed I knew all of its strengths and flaws inside and out, and this is the first I've heard of this technical issue. I am not trying to stick a nail in the coffin of the Firestore FS-100, but this might be the final straw for me... And the price is right. Anyone want an otherwise perfectly functioning FS-100? Ooops, wrong topic. :-P
strange, I have several, shoot 720P24 frequently.... never had an issue. gonna look real hard for this.
I should clarify. This is my best guess as to why my timecode is the way it is.
We are running through some trial and error to figure out if it is indeed, but the logic makes sense.
The Camera puts out a signal, 720p 24p stream inside 30p with duplicated frames (since a native framerate can't go through the FW), the firestore removes those frames (apparently they are frames 3, 8, 13, 18, 23, 28), records a 23.98 .mov file (this could have also been where I ran into trouble, need to test the P2 organizing route), but does not adjust the timecode, in other words, doesn't change the frame numbers, but they are in a proper 23.98 clip. And no one (meaning me) notices until you do try to do an offline edit.
All of my claims are pending the fault lying with the firestore and not with our stars, dear brutus...
So if this is all true, I would bet no one noticed because, honestly, this might be the only situation where the accuracy of timecode across downconverts is important. I wonder how many FS owners out there shoot in 24pN and do offline edits. I am sure it happens, but I bet its a minority of a minority of people and times.
i have been using mine for more than 1 year and half,,,never had problem.intense use,,,
always shoot QTPN ,
