Fire-un-store!!
Make sure that in the Recording Setup on the HVX, the UB Mode is set to "FRM.RATE"
Idiot.
Have you read the terms of use for the boards?
http://www.dvxuser.com/V6/announcement.php?f=56
"Respect your fellow filmmakers -- Regardless of age, experience, or opinion, you should always show respect to fellow users. Personal insults of any sort are not tolerated."
What exactly gives you the right to call people names as part of your post?
Knock it off.
The only time I had issues with my firestore was when I tried to make a cable longer than 6 feet. It work and looked like it was recording fine for a while, but then started stopping on it's own, and not starting unless I rebooted it. I ended up with a ton of bad footage. Learned my lesson and now use only a 6 foot FW cable. I wouldn't even recommend using a 14 footer just because of what I experienced with a longer cable. Oh and when I did try that cable I was only recording dv, not HD.
