Final delivery medium for HD projects?
Couple of questions
1. What is everyone using as a final form of delivery to give to clients when finishing a HD project?
2. What are you archiving or saving projects to?
3. Can a finished HD project or footage be saved to a SD DVD untill HD DVD are available?
Mike
1. Depends on what the job was and what the client wants. Could be anything from a HD Cam master to a VHS copy.
2. Personally I save to hard drives and store but, once again it depends on the project.
3. Yes. A small project can be saved intact. Larger projects would have to be split up into files that will fit on a dual or single layer dvd then reassembled on import. If you do this it often better to separate the quicktime or avi capture files into separate folders and try and leave all the project files as untouched and intact as possible.
