Final Cut is ... quiet?
Hawk Teflon
If I listen to iTunes, videos on Youtube, vimeo, etc, my audio is set to 4 "blocks" on the volume (I'm using headphones). However switching over to FCP, it's always so quiet and I have to crank it to a good 8 or 9. Then, heading back to itunes, my ears explode from the high volume. I was thinking that maybe itunes volume was too high, but everything else comes in at that level. FCP is the only thing that's that low. I can't crank the track volume any or it'll start peaking. Am I missing something simple?
FCP is giving you a flat, standard level. You need to adjust all the other apps. Look at iTunes EQ window and I bet the overall gain is up too high.
