Brian@202020
Let say you want to use a specific filter on a shoot such as a Promist, and you either don't/can't have a mattebox or don't have time to change the filter every time you change a lens, I may have a solution. Since a lot of people are using adapters to adapt different lenses with a greater flange distance (Nikon, Canon, PL, etc...) there is a lot of room in these adapters for a small filter. I will run up to the local still camera shop and experiment in the next day or so to see if there is a way to do this. Another benefit would be lens flares. If you wanted a nice lens flare without a filter mucking it up you should theoretically be able to still achieve this if the filter is behind the lens like I'm proposing. People used to add filters and nets behind the lens all the time in the 2/3 chip world. I used to AC for a guy who used to put a nylon behind the lens and said it was his secret touch and for me to not tell anyone. I'll report back.
