Filmtools 24" x 48" Converted Senior Cart (DC/NoVa)
Matt Gottshalk
Resident Preditor
Comes with Large Grip & Light Stand Caddy for Carts (I-24), and c-stand caddy.
Features
6061-T6 Aluminum Alloy Frame with Stainless Steel Rivets
6061-T6 Aluminum Alloy Nose
5 Cross Bars on Frame for Added Strength
24" x 48" Removable Top Shelf
24" x 48" Attached Lower Shelf
(2) 8" 4-Ply Tires
(2) 10" 4-Ply Tires
U- Bar is Removable and can be Repositioned
Cart can be used as a 2- Wheeled Hand Truck
30" Heavy Duty Nose can be folded Flat When Not in Use
10 Year Warranty
The Filmtools 24" x 48" Converted B&P Senior Cart is built from the ground up at our Burbank facility. It's the basis for our Camera Assistant's Cart and our Steadicam Senior Cart. We start out with a B&P 6061 T6 Frame that is assembled with aircraft grade stainless steel rivets. We've got five cross bars vs two on the competitor's model. The nose plate is made of extruded and welded 6061 T6 Aluminum as well. Included is a removable 24" x 48" top shelf and a 24" x 48" attached lower shelf.
This dude is strong! We use two 10" 4-ply tube-type pneumatic tires, rated to 350 pounds each...and steel split rims with sealed roller bearings for the best quality main wheel combination. The 8" tires which come with the famous Backstage wheel conversion kit are also 4-ply tube-type, but rated for a 295 pound load factor...that's over a 1290 pound capacity total. Please note that the top shelf is limited to a 200 pound capacity.
The "U" bar with red handles is removable and stows horizontally, so that you can use the cart as a two-wheel hand truck. The 30" Heavy-duty double-riveted nose lays flat on the lower shelf when not in use. The top shelf removes easily and can be stowed with two bungee cords (included) for local transport.
Paid over $1400 new, but is much too big for my needs.
Will sell for $900 obo in the Metro DC area.
Will deliver within reasonable distance.
picture.php
picture.php
picture.php
picture.php
