Is intercuttable a word?
Anyway, my question is; If 1080 and 720 GH1 footage are intercut on a filmout, will the images look noticably different when projected onto the big screen?
And 720p from the GH1 looks poor blown up to my 100" projector, badly shot or whatever it has much less sample areas for colour resolution and luminance, and is worse than I expected. I've tried every combination going to make 720p look good and it just doesn't have sufficient colour resolution.
True, but what does that have to do with your issue of sample area and color resolution? I can go into other feature films that were blown up from SD to view on the large screen that looked good.(I wasn't that impressed with Crank 2, but isn't the main camera XH-A1 - 1440 x 1080 and not a 720p mode?)
Don't get offended but I think maybe your problem is comparing the GH-1's 720p to its own 1080p. There will be a difference, yeah, when blown up....but is it passable compared to other cams that have been used on the big screen...more than likely yes. I'm also intersted in knowing what your method of upscaling is. This might be the problem.
How do you upscale the 720 to 1080?
Projector's internal scaler - which does a reasonable job.
All I'm saying is when 720 compared to 1080 directly there is no comparison. That's why you have the 1080/25 mode. And it's specfically the colour in detail backgrounds give it away.
Try proper software rescaling like scaling up in After Effects or even better use Red Giant Software's Instant HD / Resizer advanced package. The scaling in NLEs are geared toward speed over quality.
http://www.redgiantsoftware.com/pro.../adobe-after-effects/magic-bullet-instant-hd/
http://www.redgiantsoftware.com/pro...be-after-effects/magic-bullet-instant-hd-adv/
well I don't know much about filmout but as I recall 28 days later was shot on SD dv and to me I thought it looked decent on the big screen. I'm sure they spent tons on post but hey if they can do it with dv they can do it better on 720. Just the right people i suppose.
Well I'm going to say that my mileage has varied.
I recommend bearing in mind that uprezzing alone will probably not be enough to intercut with 1920x1080. You will likely also need to add a judicial amount of sharpening.
