C ceaguila New member Jan 19, 2013 #1 Can you use a regular 40 inch samsung HDTV as a field monitor for the panasonic af100? I mostly want it to see if everything is in focus. Then use the waveform and zebras on lcd screen to watch the exposure. Is this possible?
B bengiles Well-known member Jan 19, 2013 #2 Yes. Might need a big field, though. HDMI out - and you can toggle on or off the various status icons/waveform etc on the HDMI output. Look in AV in/out settings. Ben.
C ceaguila New member Jan 19, 2013 #3 oh that's perfect! so you can also see the waveform in the hdtv? Obviously it won't perfect as a professional monitor but this would help
S spotts Active member Jan 19, 2013 #4 Waveform monitor and zebras are internal only and cannot be seen via HDMI or SDI out.
C ceaguila New member Jan 19, 2013 #5 Ah okay. But i can still see them on the camera while I'm connected to the monitor?
J jmarkham Well-known member Jan 20, 2013 #7 Wow, I can't imagine hauling a 40" around to pull focus. We've been pretty happy with the ikan VX7i as of late. jeff
B bengiles Well-known member Jan 20, 2013 #8 spotts said: Waveform monitor and zebras are internal only and cannot be seen via HDMI or SDI out. Click to expand... Sorry, my mistake - not zebra, focus assist, scopes and iris level meter - but you can get the menu displays, level meters and markers etc. The toggle is "Video Out OSD" in the AV IN/Out menu. Ben.
