jafyats13
Alright.
So I'm trying to keyframe a filter. The widescreen filter in this case. I key multiple points right where I want them. Then, I render and they reset. The numbers and dots still appear to be at the places I wanted them. For instance, I set one point to -40 and the next to -45. After the render they still say those numbers, but no longer correspond to where the image should actually be keyframed.
However, if I then try to either increase or decrease the numbers to change the image placement back, I immediately have to render again and I end up having to put all the numbers back to the original ones I thought they should be. I hope this makes sense.
I've always been able to keyframe before. Even on this project and on this Final Cut. In fact, I was working on it one night and then the next morning, I opened up the project and could no longer keyframe. It just doesn't work after I render. Any suggestions?
Thank you!
This is FCP 5.1 by the way.
Thank you!
