FCP + new Macbook Pro = jittery preview
stevenblatter
I just recieved my new MacBook Pro 2.2Ghz and I have a problem with FCP 5.1.4 playing back DVCPROHD 25P footage on the Macbook screen and using the DVI output on my JVC DT-V24L1.
The picture is all jittery like if the frequence of the LCD was wrong.
Doe's anybody have the same problem? Is there a solution?
Thanx,
Steven
http://www.prog-pics.com
The solution is that you are not monitoring correctly. Buy a Matrox MXO and then monitor via SDI (if you have he SDI model of the JVC) or component. You are attempting to use the JVC as a computer monitor rather than a video monitor in proper YUV color space.
Ned Soltz
Thanx but on my G5 I could use the JVC in DVI without any problems and now even on my Macbook Pro screen I have this flickering.
It is perfect when I play a video using Quicktime but the flickering is only when I view videos in FCP.
Maybe FCP 6 work better on a MBP.
I tested the MXO and I didn't see any difference between DVI and SDI...
so for me 1000$ is much to expensive for a box that doesn't have inputs!!!
Steven
There is significant difference between monitoring via MXO and just monitoring a computer image. For one, you are in the proper color space. That is essential for color correction. The MXO also allows for a variety of other functions from simulataneous SDI output to realtime downrez. If you do not need inputs, then the MXO represents the best monitoring solution. If you require inputs on a MacBook Pro, then your only option is going to be the IO HD which, when released in coming weeks, will be $3500.
Ned Soltz
What are your FCP preview settings?
FCP has crap previews unless you go and set it to high quality. If you have done this already, then I don't know what to tell you...
Hope this helps.
Viet
Steven
