FCP 7...problem with stills in my timeline
For some reason, some stills that I drop into my timeline show up with a green render bar while others show up normally.
Does anyone know why simple jpegs dropped into a Apple Pro Res 720p59.94 timeline would require rendering?
What I can't understand is that some jpegs show up normally (no render necessary, as in grey render bar) while others show up with green render bar.
I always thought that when you drop any still into the timeline, it doesn't need to be rendered unless you zoom in on it.
are the jpegs 72 dpi, or a higher dpi?
Are they RGB or CYMK?
For the most part, more than 72 dpi produces no better image, and usually involves rendering.
I've had fast editing results by using .psd with no layers, only everything flattened to a background
