FCP 7 file format question for the sequence
jondoe
I'm editing a short film in FCP 7 and every time i add a new clip (that was recorded from the same 7d) to the timeline, it needs to be rendered. Then after rendering, if i move the clip, it needs to be rendered again. I have mpeg streamclip and I was wondering how (or what settings) can i convert them to a format so i wont have to render with each slight move of the clip?
Well, to start, your project and sequence settings need to match the codec of the footage you're editing.
However... your footage is sourced from a 7D. Are you working with the camera's native files, or have you converted them to something else (and if so, what)?
The 7D's h.264 files are not in a codec that FCP 7 is going to like very much.
you should convert all your 7d footage to a flavour of prores because fcp can't edit h.264 natively. you can either do it in log and transfer or use compressor.
Ive just dragged them over from the 7D and it is currently in the H.264 format. Its weird because some of the footage will play while others wont. My sequence setting is set to:
Frame Size - 1920x1080
Aspect Ration - HDTV 1080i (16:9)
Quicktime Video Settings\Compressor - H.264
Audio Settings - 48 khz, 16-bit
I'm not too familiar with Compressor however I do have Mpeg Streamclip. When you say a "flavour of prores", (specifically) what settings should i set my conversion options to?
Also, if i wanted to render it out (so far), then re-import the rendered version back into FCP, what settings should i render it to? The reason I wanna do this is because Ive done alot of editing however I have alot more to do. Its seems like the play-head lags near all of my cuts. I figured if I rendered out a version and worked around that, it would be easier on the computer (because it would have cuts and tracks to deal with). Hopefully that makes sense
FCP does not like to play with h.264. Further, h.264 is a distribution (read: end-user) codec and was not designed for editing. The reason your playhead lags at all the cuts is because your computer is trying to decompress the h.264 codec on the fly (what are the specs of your Mac, by the way?). And the reason you keep having to render is because, again, it's not an editing codec.
You should convert all your footage (MPEG StreamClip is great... better than Compressor, actually) to ProRes LT. Then set your FCP project to the same. This will probably mean starting over on your project, but that's going to be a lot less of a headache than trying to retro-convert. If you print out an EDL, you can at least get back to where you left off a little more quickly. At least you know now, and you can start your next project on the right foot.
Thanks Alex, for explaining it too me. Is there any other settings that I should make sure to check\select in MPEG Streamclip? I'm assuming that converting to that codec wont degrade the quality in any way.
Also, when going to Adobe After Effects, do you have any recommendations for sending to AE?
I've never heard that before. I'm curious as to why mpeg steam clip works better? :)
OP: what i meant by flavour of prores was to transcode everything preferably to prores LT. anything else would be overkill.
you are correct. transcoding to prores will not degrade the quality in any way.
Compressor is clunky and buggy. it locks up and crashes fairly easily. It's also not as fast as StreamClip, and doesn't support as many codecs. I do like some of the presets in Compressor better, but that's mostly for transcoding final exports or prepping fro DVDSP. When it comes to transcoding before the edit, StreamClip is my go-to.
Do you have any advice on exporting to AE and Final Export settings? My school says I should export to the Animation compression codec but what are your thoughts?
Not sure about AE, since I don't use that program.
For final export, it's best to export a FCP Movie, self contained and at current project settings. From there, you can use Compressor or MPEG StreamClip to convert it to whatever you need... for Internet, DVD, etc.
My experience with Compressor is completely different. I've had very few problems with it. It seems reasonably fast on my current 8 core (and was reasonably fast on the G5 it replaced), and it supports EVERY codec I have installed. Plus it gives me a lot of control over the transcode & scaling, and let's me set destination folders with ease.
I've tried mpeg streamclip and it just doesn't see my mts files. grayed out. Can't seem to get fcp 7 log and transfer to work either.only thing I have had work is Clip Wrap.
FCP doesnt recognize mts files; however if you log& transfer the whole folder(that has the mts files) from the card or camcorder, you should be able to see & convert them problem free*
*provided all necessary plugins are installed into FCP beforehand
