dougspice
This is a repost from elsewhere but I'm under an extremely tight deadline so I hope no one will mind...
THE FOOTAGE: shot to P2. SD, DVCPRO50, squeeze mode, 24pa.
I copy the footage first of all to the hard drive. Then I go through Import->Panasonic P2 in FCP and find it. I go into settings and "Remove Advanced Pulldown" is checked. Okay. I log and name some footage. I click Add to Queue and watch it go wheeeeeeee!
Now. I open the footage in FCP and discover duplicate frames! I discover that it is 29.97! I discover the occasional extremely evident interlacing! I become concerned.
I open the same footage in Quicktime and confirm the same problem. What to do?
I open the same footage in After Effects and, when I try to automatically Guess 24pa Pulldown, it gives me a suggestion! However, it ALSO gives me a suggestion if I ask it to Guess 3:2 Pulldown. Okay, so maybe it's possible this footage was shot 24p, and not 24pa (although I really don't think so. Is there a surefire way to tell?)
Even if that WERE true, I shouldn't be seeing this horrible interlacing, should I? And why can AE deduce that maybe there are frames to be removed, but FCP can't? Note that there is zero difference between the footage I get from FCP's P2 importer if "Remove Advanced Pulldown" is checked or if it isn't.
90% of the time I feel like I really understand this camera and this workflow. The other 10%, though, I'm just absolutely drowning.
