I recently bought a used NT2-a becouse I was interested in it's low self-noise for
sound effects, VO and similar. When I got it I did a short test on speech
recording it on it's own and simultaneously with a C414B-ULS and a U89 that I
have access to. The NT2-a sounds pretty good I think, but the self-noise was
much higher in comparison. I wonder it's faulty (it has a faint smell around it,
not a good sign), so I hope anyone has some experience with it.
I tried looking for some other tests made on speech to compare, and
all I could find was one by Ty Ford where he speaks 6'' away and doesn't have
much silence. I used that as a reference for levels (he also had a test on a U89
that I put in as well, just to se the difference in room etc).
Here's a link to a zipfile with the clips,
recorded in 48kHz and 24bit. The only processing is a bit of level balancing, to
put everything at roughly the same level as the NT2-a test by Ty Ford (it's not
exact, but should be good enough to tell).
http://www.2shared.com/file/a96yhcGH/NT2-A_test_possibly_faulty_mic.html
Test 1 is a short comparison between
the different mics in a sound booth, all using a cardioid pattern and the
speaker being about 8'' (20cm) away. The speaker (myself, so excuse the swedish
and a little mouth-noise) is talking a bit softer than Ty Ford (I suspect he
also processed his a little), so this should be taken into
consideration.
Test 2 is the same setup with the NT2-a only, using both
cardioid and figure eight, and then a closer take 3'' away in omni.
Test
3 I tried to match Ty Fords test more closely, about 6'' away, and speaking a
bit louder. Figure eight and then cardioid.
If you have any questions
or want me to do something different with the files, just let me
know!
consideration.
Test
know!
