Why would you want to unwrap/rewrap on a pc ? Pc can edit/play mts files natively. I don't see any reason why you would waste time on a pc?
You can with ffmpeg (command line application), you could even make a batch file (.bat) to batch process all the files in a folder for example
e.g.
ffmpeg -i input.mts -vcodec copy -acodec copy output.m4v
(btw, m4v is just a modified mp4 container)
mmm... so you're saying: ditch the rewraping, transcode to a lesser quality DNxHD for offline editing, and then batch import to the optimal DNxHD for online..
well maybe that's the best option (especially when dealing with big projects..)
the thing is- that avid MC5 can work natively with m4v, so if i rewrap i don't need transcoding (although it's a lot heavier on CPU)
thanks for all your interesting tips![]()
Can't avid take the files natively ?
