Mark Crabtree
After a lot of experimentation, I seem to be getting fairly stable 24pn at GOP 2 and 54 mBS.
I have not tested the 720p only the 1080p.
It will crash if you are recording very dark almost black scenes or cap on. If there is any kind of bright area, even a small one in the frame is seems to keep recording. I have not had a crash other than recording black and the famous chart of doom which it will record for more than 10 seconds before it crashes. I have let it record for over ten minutes at a time on busy high detail scenes and had no crashes. I hardly ever do longer takes than ten minutes so I have not tested longer. I see no strobe effect and the resolution is very high with the GOP 2. I tried to up the over all rate to better handle bursts of high data rate. I also tried to keep all the numbers multiples of 9000.
I just shot a green screen for a TV spot and it keyed perfectly.
Here are my settings.
Ptool v3.50d
GH1__133.bin
Prevent version compare Check
Battery Third party Check
Interface all languages Check
AVC
Wrapper Native 24p Check
AVC compression
FHD 54000000
H 45000000
L 45000000
Overall bit rate 99000000
AVC GOP
720 60P 3
1080 24P 2
Patches for Testers:
AVC HD Movie Mode:
Preset bitrate 9000
Preset bitrate 2 9000
Overall bitrate 108000000
Ptool v3.50d
GH1__133.bin
AVC
AVC compression
FHD 54000000
H 45000000
L 45000000
AVC GOP
720 60P 3
1080 24P 2
AVC HD Movie Mode:
Preset bitrate 9000
