This is a Falconeyes RT-24TDX in excellent condition - $415
That’s a 2x2 BiColor Roll-Flex LED panel with adjustable Kelvin from 3000 to 5600 degrees.
It includes a chimera type diffusion frame with diffusion material and a foldable honeycomb grid.
Compatible with DMX 512 and Supports RC-3T 2.4G wireless remote control (The remote not included).
Powered by AC or V Mt battery with both adapters included.
Cloth Carrying bag included.
The light can be mounted on a stand or clipped or taped to any surface.
There is also an optional diffusion front that can work as china ball to throw even light around a room from above.
This is the older type frame and bag which is a 2x2 “X” frame . It works perfectly well but packs up longer than the new version.
I am selling because I also have an Intellytech TC-160 and want to have both 2x2 LED’s match.
The new version (only the frame and bag are different) is $569 on Amazon.
https://www.amazon.com/Falcon-Eyes-3.../dp/B075QD1DP4
(Link to China Ball coming )
I’m selling for $435 including Paypal and shipping Conus
Its a great light. Higher output and softer than a DIVA light + it can run off a battery and has adjustable kelvin.
Photos and links coming.
Note: I have ground away the area around the power tap on the V mt adapter. This affects nothing.
When I got the unit I noticed the metal housing around the power tap made it impossible to access so I used a dremel to grind that away. Unfortunately afterwards I discovered that none of the power taps on these units are connected anyway, so it was a waste of time.
They probably just came supplied on the V mount adapters.
Lenny - longtime DVXUser member
