F55: F55 and Fuji 20-120 Zoom, incorrect lens data
Straw Man
Hoping someone can help -
Currently have a Fuji Cabrio 20-120 zoom on the F55. Lens is powered through the mount, zoom and rec trigger are working, but T stop data is incorrect. The lens is set to T3.5, but in the viewfinder the F55 says the lens is T5.6. Anyone know how to fix?
If you haven't already, try switching the lens type in the menu. WIth my 17-120, it's set to Type C, because they use the Cooke i-data protocol. Not sure if Fuji uses the Cooke of Arri protocol. I've shot with the 20-120, but it was on an Amira, not my 55.
Presuming same as the other cabs.. 19-90 etc..
f55 lens interface set to type C ..Cooke
Dip switch on lens.. S2 set to off. (its under a rubber flap front of the servo motor hand grip
Thanks all. Ended up needing to run a full initialize once all other dip switches were set correctly. For anyone else who may come by this...
Power up camera while holding VTR+RET on servo, keep holding until zoom wheel initializes then release. Allow lens to work through zoom/focus/iris initialization, LED on front will go out once process is done. Power off camera and power back on. Lens should now be talking correctly with F55.
