puts them quite close. So the F5 (with the software upgrade) and the F55 are identical other than wider color gamut, ITU-R BT.2020 color space, global shutter, 4k frame rates and mount ring color?With $1000 paid update...
Yes, with the paid update there is really not a lot of difference between the two.
The global shutter, wider gamut and 4k @ 120fps are the big draws for the F55. Certainly if you're shooting super-saturated colours from neon or RGB LEDs, the wider gamut of the F55 really comes into its own (where the F5 can run into some weird colour clipping and artefacts).
If you're not shooting rock concerts or more carefully posted work like narrative or commercials, I think the F5 is more than sufficient. For the more visually demanding projects though, the F55 does have a definite edge.
Thank you all for your help.
Great points Grug.
It's great to have the option to upgrade from the F5 to the F55 if it becomes necessary.
Has anyone found a preference for the global shutter in non obvious (high speed sports, flashing lights, filming trains...) situations? For example, noone seems to talk about the way the global shutter image moves when the camera is on the shoulder. Does anyone have any thoughts here?
I have to agree about the global shutter. To me the global shutter alone is worth the price. Once you have the freedom afforded by a global shutter it‘s indeed difficult to set for something else. When you think that just a very selected few belong to the exclusive global shutter club, the F55 becomes an obvious player. If I was out to buy either a F5 or F55 and could afford going for the F55, it wouldn‘t even be a question. F55.
Run&Gun;1986717895) frame rates with the new R7 RAW recorder-120fps @ 4K RAW & X-OCN 4K. The 5 tops out at 60fps. [/QUOTE said:Been wondering recently if that could be hacked too - I always assumed that it was a hardware limitation in the F5 that meant it couldn't go to 120fps, but didn't they say that about internal 4k and got found out? Quite obviously the serious hardware is in the R7.
Personally I think the people ditching the F55 for Venice are making a huge mistake and will be disappointed when it is not a full camera until 2019 and beyond.
Right now is a great time to buy a used F55. I've seen them as low as $12k USD on eBay as many F55 owners sell off their cameras moving over to the new Venice...Personally I think the people ditching the F55 for Venice are making a huge mistake and will be disappointed when it is not a full camera until 2019 and beyond.
