starcentral
Not to be an alarmist but incase any of you rent, borrow, or buy an F5/F55 be warned about using a popular external 5.6" monitor that has been known and documented to cause shorts on the SDI boards located in the F5/F55 camera due to putting DC voltage on the ground of the SDI BNC input of the camera. (part of reason Sony is offering free upgrade to newer SDI boards on the cameras)
Sony will not come straight out and specify which monitor is causing this issue, but it seems somewhat concluded by camera users that it is the Small HD 5.6" monitor. Sony has also said that the issue seems to mostly only affect F5/F55 in the USA and that it would probably not affect consumers in Canada, Europe, and other countries, due to higher electronic standards.
Regardless you might want to keep any 5.6" monitors away from these cameras, or an alternative is to hook everything up before powering it up. Oddly enough any 7" monitor is fine.
