Im considering the 7Q for my F5 for just it's exposure tools/Oled/monitoring capabilities. Even without considering it's recording features, what it offers for the price pretty much beats out the competition.
That's expensive for just a monitor on an F5/F55 but then again the Sony LCD or OLED is really expensive comparatively.
Remember also that Sony has indicated it will be putting a waveform monitor and histogram on the F5/F55 (free via firmware). Hopefully that's out before the end of the year.
The thing is has any tried to move camera setups, shoot off-the-shouder, low-angle handheld, etc with a heavy-ish 7" monitor on top of the camera with noga arm? There are other reasons to look at the Sony solution. It's not a problem for studio-based shoots, but it is tricky on location with a small (or no) crew.
My bad.. I meant the 7, not 7Q. Yeah, that would be a little spendy for just monitoring.
Yes I work a lot with the camera on full day shoots with a 7" mounted to top handle using a ball mount, and for some setups an articulating arm with the LCD to one side. I went with the OLED VF on my F55 but my 7" gets far more use. I think its just what you get use to perhaps.
Bhphotovideo sells the hirose to DC plug, or you can source out your own connector and build your own. I forget the max current draw each hirose connector is rated for but you should have enough for a monitor.
