That's the F35 Manual. Go to page 36 for the step by step.
Forum answer: If you're in S-Log mode, white balance can only be Tungsten or Daylight, no inbetween. You can set it with the assistant panel or LCD side menu on the body. Go to the page that says "TUNGSTEN" or "DAYLIGHT". If you don't know how to operate that menu yet, then you oughta have a look at the manual. To have full white balance control you have to be in custom. Again, page 36. Have a look-see.
I generally found I preferred to stick with either Tungsten or Daylight. If the "daylight" setting feels too warm, you can use an 85 instead (rather than the correct 85B)
