Poll to F35 owners:
1. Does your top fan blow down or suck air up?
2. Does your back fan suck in or blow out?
I have seen cameras in both configurations. I think air blown in from all fans is correct.
I have spent the last week chasing the “max fan” issue by taking the camera apart 25 times and swapping parts 1 by 1. You will get this error anytime 1 of the 3 fan boards isn’t connected or fan isn’t connected to one of those boards. If all 3 are connected the problem comes from MB-1100 board, it is $700 part, and a real pain to get out of camera.I am hoping to find failing component and learn to repair. This issue seems to exist in a few cameras, the camera functions fine except for max fan stuck on. The mb-1100 is the main motherboard everything plugs into. This is why random things like plugging in ENG lens will effect the error, all inputs plug into this board.
Now for some interesting things:
The CCD gets noisier when it gets too hot. Running a camera for a few hours with low fan it gets noisier. At this point if I switch fan modes you see the noise reduce with fan turned higher, even better with top off.
Removing the memory stick module, and the 12v/24v/Ethernet module and cables has lowered CCD temp for me. In fact removing all the unused cables and parts the air from the back fans can be felt through the camera now.
I wouldn’t recommend tearing your cam apart but keeping fans on high until shooting could help. I will try to conduct a more scientific test with temp probe and photos but I feel the F35 image grain is effected by heat of CCD.
