Hunter Hampton
Carbonite Member
Just an idea here, looking to see if its even possible. Love to hear your collective thoughts:
Idea:
1. Take speed booster for E-mount
2. Remove focal reducer optical block (the part that makes it a "speed booster")
3. Insert "speed booster" block into housing that slides into F35 lens port
4. Gain 1 stop in sensitivity/DOF when used with appropriate lens
Why do this:
1. Would breath even more life into F35 by allowing you effectively "increase" the native ISO to 900 instead of 450 in S-Log gamma. Would really come in handy for low light scenes as you would gain 1x stop.
2. Would allow for very shallow DOF/Easier access to wider angle lenses
3. The f35 has some serious FILM Like mojo, this would allow night scenes to be captured on f35 that are currently not possible
Why this might work:
The optical block in the speed boosters is pretty thin and narrow- It MIGHT be physically possible for it to fit into a housing that slides into the F35 lens port up against the glass filter in the f35 lens port. No permanent camera modification needed.
What are some possible issues to consider:
1. Focal Flange Distance (may not be possible)
2. Would require longer PL lenses or 35mm SLR lenses (in order to shrink down the larger image circle to super 35 and gain the stop)
What do you think? Is this even worth considering? Am I crazy? (YES!)
Idea:
Why do this:
