F3 vs FS700 with 7Q
ReelFilmGeek
So I have only found a few pieces of information about this online and they all seem to be a little outdated before the FS700 got the sLog update. So I was wondering if anyone had any input? Now I imagine the detail in the FS700 would be better since you can do 4k raw to HD with the 7Q, and it also has the advantage of crazy frame rates, however how do colors compare? How are the skin tones between the two, is there much difference? I know people have sometimes called the F3 the poor mans Alexa due to its dynamic range and how it handels highlights but now that the FS700 has been updated where does it stand?
Besides 4K resolution, the sensor in the F3 is superior to the sensor in the FS700. Period.
As for highlight rolloff...doing 4K>HD gives you much smoother rolloffs. So that's taken care off.
Color? I found the F3 to be non-Sony look for skin tones. The FS700 is Sony look skin, but I don't find it all that bad.
FS700 vs F3 skin tones test
https://vimeo.com/45153740
However, there is much more to consider when buying a camera than just the sensor. The FS700/O7Q+ combine to make one of the best solutions available today. The codecs, frame rates, security and monitoring functions all trump the F3. (now add 4K to that)
If I had to choose one, it would be the Fs700/O7Q+.
That's what I was leaning towards if I can get one for a good deal. The FS700 is really pushing my budget compared to the F3 but with the 4k capibility (I'll rent the O7Q on jobs I need it for now till I can afford my own) and slow motion features it makes it really tempting to try to find the extra cash for one.
is the highlight roll-off better on the FS7? I shot ProRes recently for the first time on my O7Q and was quiet unsatisfied with the highlight roll-off...looked very unorganic and 'videoish'
You need to work with the highlights in post usually, no matter where they're from.
A smooth rolloff is really about desaturation as you get brighter.
All cameras attempt to retain as much information in the channels right up to clipping, which is perceived as harsh highlights.
One of the benefits of FS700+O7Q is RAW, which allows you to smooth off highlights more by highlight recovery (which requires un white balanced data ideally), compared to an F3.
Just pop a decent emulation LUT on the footage that has the kind of highlight treatment you like and you should be set to go
cheers
Paul
Hey hey RealFilmGeek! ;-) I remember you mention this is your name here on our FB chat the other day.
My view on the FS700 + Odyssey combo is you're pushing dangerously up into FS5/FS7 pricing territory (though this might change if FS700 secondhand prices come swiftly down, after their recent brand new price drops). And FS7/FS3 are way waaaaaay more preferable from an ergonomic / workflow perspective vs the unwieldy FS700 / Odyssey combo.
While the F3 has the compelling case that it is dirt dirt cheap (and now HD 10bit 422 recorders are dirt dirt cheap too!! Thanks Atomos and BMD).
But in the end it is a rather personal preference, depending on your shooting needs and budget. (My budget is very low, thus F3. And I'd rate ergonomics/workflow over tiny amount of extra ultra image quality, thus out of FS7/FS5 vs FS700&Odyssey I prefer the FS7/FS5 options instead)
Yeah the fs700 doesn't seem to be going for as cheap as I hoped used and the o7q would of have to been a later purchase. Sucks I won't have the super slow motion but I can rent when needed for those projects (even though t would of been fun to play with) so now to grab an used F3
Is the test in this vid still relevant? I find the FS700 to be way more pleasing with skin tones since Convergent made their tweaks on the 7q. The Pix240 at that time wasn't taking advantage of the 4k goodness coming out of fs700r in the same manner that the 7q/+ is today, nor applying the knowledge that Convergent has gained tweaking their line to the output of the fs700 raw signal. I'd love to see an update comparison, especially since i'd like to pick up an F3 as a possible b-cam. Someone posted an incredible music vid shot on the F3 in one of the other forums.
