Lenilenapi
Carbonite Member
I have been having the most inexplicable problem I can recall in over 30 years.
I shoot a quarterly interview w a CEO against green screen and we've been shooting it with an F3. When they went to green screen we added a Ki Pro which worked fine a few times , then one day the recorder kept stopping and restarting through the run always leaving a few seconds out at each juncture. No steady rhythm- sometimes short sometimes a few minutes before it glitches.
Shooting 1920x1080 29.97 P We are using a Sony paintbox, and though we have a cable loom w BNC and audio cables , we use a separate BNC from the SDI A to the recorder ,
We could not get this to happen again back at the shop no matter what we did - so don't know what the problem was. Tried every combination of settings and triggers.
So we switched to a Samurai - Great for 2 quarters then something similar happened. This time there are little glitches or jumps in the recording where the image jumps to the side for a frame. Occasionally it stops and restarts. Then sometimes it is fine for stretches of a few minutes.
However this time i realized I had erased the drive in the computer rather than reformatting so I figured maybe that was it.
Nevertheless I tested and tested at home - every combination of erasing in computer, triggers, source on HD-SDI, I could think of to no avail. could not repeat the problem. But i figured must be that I didn't Format.
Next quarter it happens again. This time we test beforehand and run for 5 min a few times and it seems fine. But we do have an odd problem in that the Samurai won't start from the Camera trigger. So we hit record on the samurai- and sure enough we see glitches only when our CEO is talking. Thank God for XDCAM internal back-up .
Nowt have just spent a day trying everything I can to repeat this problem and nothing goes wrong - using the same Sandisk Extreme drive 240G SSD and the bad files are still on it - it hasn't been touched.- AC/ battery / with and without triggers on the Samurai or recorder, blah blah blah.
Any ideas. I am at a complete loss. Will send bad file to Atomos and put a small sample up here.
