You're talking about a Nikon adapter right?
There aren't any issues but that's because no Nikon adapters carry electronics.
Although its called an Nikon F it sounds to me like an F/G adapter as its described as having a mechanical coupling to the iris inside the Nikon lens , and a wheel, handle or some devise by which you can smoothly adjust the iris ( click less) . That's in addition to thef stop ring that may already be on the lens.
F stop #'s aren't marked but there is a scale that you can deduce your iris from.
No auto focusing ( none of the metabones do that fast enough) and unfortunately no Image stabilization.
There is no focusing through the wheel, it is only mechanical focusing like you are used to . The adapter is only for the image, no other functions.
My point about about G is that you will be able to adjust the iris mechanically with this adapter . Again no electronics, nothing to do with the wheel.
I tried the G-lens adapter from Metabones and it works okay.
But be aware that the throw of the iris control ring is very short.
Approx. 45 degree from open to close without real marks sothat
you never know which stop is adjusted.
I have the Metabones F to E adapter (non-speedbooster), but it has F-stop markings 0-7. The rotation amount to go from wide open to closed is identical to the amount of throw on the iris of my Zeiss ZF 50mm f/1.4. It's probably around 45-degrees of rotation, like you said, but that's a lot more than the throw on the ring that's on the Novoflex adapter.I tried the G-lens adapter from Metabones and it works okay.
