[FS: General] EZ-Slider 32.5 inch Linear Slider, similar to DP slider and Cinevate Atlas
Rocket_Dog
$450 - EZ-Slider 32.5 inch multi-functional Linear Slider system. It's about 6 months old and in excellent condition.
It's almost identical in design to the DP slider but I prefer this one since it's much more low profile and a less dangerous for little kids running around than the DP slider when tripod mounted. The feet are also much better than the DP slider.
features:
The versatility of the E-Z Slider will make it a favorite tool for your film, event and corporate productions. Check out the features of the E-Z Slider.
- 3/8" tapped center hole for direct mounting to a tripod or attaching a quick release adapter plate. 1/4" tapped hole so quick release plate can be attached with two screws.
- 3/8" and 1/4" tapped holes in end plate for mounting to a tripod or to attach a quick release plate in vertical mode.
- E-Z Slider mounted vertically on a tripod with a quick release plate. Simulate crane motion in vertical mode.
- Non-marking rubber feet and 3/8" tapped hole for light stand adapters
- Carriage with permanently lubricated ball bearings, rubber bumpers and brake.
http://www.ambientsky.com/sale/all/Images/29.jpghttp://www.ambientsky.com/sale/all/Images/28.jpg
Save over $100 off a new one.
http://www.e-zslider.com/store.html?page=shop.browse&category_id=7
just to clarify, this is frictionless plastic slider - meaning it's nowhere close to reliability of the move of the ball bearing design such as cinevate.
you're wrong this one utilizes the same PBC redi rail as the DP Slider, so it's ball bearing and it's frictionless.
