Extremely flexible focus tool
marcus3208
If you have ever used a 1 degree spot meter, you know how easy it becomes to choose the critical spot for metering. Imagine this spot actually is two-way with an near-infrared grid pattern (led powered) being projected on your chosen spot. Being near-infrared it is easy for the camera sensor to pickup and the grid pattern makes it easy for autofocus to select for maximum focus contrast at that point.
Problem #1. Although near-infrared is not a visible distraction to actors, the focus grid is necessarily visible to the camera sensor, so it will need to pulse VERY briefly when the button is pushed or synchronize between recorded frames to avoid being recorded.
Problem# 2. Infinity or near infinity is too far for a projected grid to work, so the most distant focus point in any shot might need to be chosen in camera as the default for any time there is not a visible grid focus point at a closer distance. A second button on the grid projector could select this default focus distance for the camera whenever needed. The speed of rack focusing would also need to be adjustable for this circumstance based on creative choice.
It's wild, it's crazy and it's too late for the contest, but it would make the focus puller's job much easier by just repackaging existing tech.
