Which would be the best choice to pump up the footage?
Not with an AF100 or any other HDMI or HD-SDI output device. 4:4:4 requires either dual-link HD-SDI or 3GSDI.Thanks a lot for the Information guys. I really appreciate it. So for what I see, with the cinedeck extreme I could pick up 4:4:4 ?? Is that actually possible?
So are pretty much every camera out there anyone would be likely to use it with. AF100, FS100, C300, they're all 8-bit. Only large-sensor camera anywhere near affordable that has 10-bit is the Sony F3.Let you know, NanoFlash is 8 Bit.
(same thing with price, more expensive things are better.. because they're expensive.. or something)
Higher bitrate will improve IQ.
Ask my wife about this!
The Atomos Ninja and Samurai can also use spinning disc drives, not just SSD drives.
Atomos Samurai
$1800
- Records to ProRes 4:2:2 10bit
- SSD Drives
- HD SDI
- Supports Timecode
- Onscreen Playback
Atomos Ninja
$1000
- SSD Drives
- HDMI
- No Timecode Support
- No Onscreen Playback
