Nick Royer
I'm coming from an FS100 - which I was able to use with an HP monitor (ZR2240w) via the HDMI cable. However, with the GH4, I haven't been able to get this setup to work so far. It will work when the camera is in AVCHD mode, but in MOV mode, it will only work if the camera is set to 59.97Hz and 60p. Setting to 23.97p or 24p (at 24Hz) does not seem to work, as the monitor reports that it is outside it's signal range. So, is there a workaround, or is it time to get a new monitor?
