Exposure problem with Nex-5t and EF adapter
charliemcdanger
I bought a new Nex-5t on an Amazon lightning deal and mostly think it's great. However, there's one issue that might be fatal for my purposes. When I attach my Canon lenses via a Fotga adapter, the exposure in video mode gets a mind of its own. I demonstrate here:
http://youtu.be/KnIo2i5EsaY
The problem is severe enough that most footage shot in full sun becomes unusable.
I've set everything to manual and turned off every conceivable automatic option in the menus. When I put the Sony kit lens back on, the body operates as it should. All ideas and solutions appreciated.
Alright well it seems people could give a flying f---, but in case anybody in the future of time and space has this issue, I figured it out. At one point I switched lenses and stuck the 1.8 on my 7D, and noticed that the aperture was wide open--even though the screen on the NEX-5t had still shown the aperture stopped down.
It turns out every time I hit record, the camera (or adapter, whichever you want to blame) was opening the lens to maximum, without changing the indicated f-number on the LCD. You can, however, still adjust the aperture. The trick: spin it toward open until the LCD registers the lowest available f-number, and then you can stop it down as normal. Alternatively, figure out the right f-number, then open the lens wide, hit record, and return the aperture to the correct setting. I don't know why the camera does this, but at least there's a solution.
Also, how's it in the future? Thanks in advance.
