Colinelves
How are people exposing 2K/4K at the moment? so far I've done one project at 4K (Sony recorder) exposing for ISO 2000 - and the result was extremely noisy.
Since getting my O7Q I've done a couple of shoots at 2K Raw. The first I exposed for ISO 1000 and it still seemed quite noisy. The second time I exposed at ISO 640 (as Cine 4 seemed to be a good flavour in 8bit land) and the results were very good. Nice clean blacks, but still maintaining a decent roll off in the highlights - and holding the clouds (albeit on a very grey day!)
Post wise I imported into Resolve, set camera raw to CinemaDNG, Gamma & colour BMD film, high light recovery and colour balance as shot (I used preset daylight for both shoots at the second was all exteriors and the first I light with my LED panels set to daylight) and set the input LUT to the Convergent Design Slog2 to Rec 709
I then did a quick one-light: pulling down the gamma by 0.15 (to correct this apparent gamma problem) and exported to QuickTime (2K DCI frame).
Exposing this way I got really good skin tones and since It needed no exposure correction was applied in the Raw I suspect the CD LUT assumes a base ISO of 640, or there abouts.
BTW: by 'exposing at ISO 640' I mean I pulled out my light meter, set it to ISO 640 and the shutter speed and set the stop based on the meter reading. I know some people advocate ETTR - but that's a bit of a ball ache for long form work.
At some point I'll check where skintones fall when exposing at 640 - so I can setup the zebras correctly for docco work (once it is possible to set the zebras below 70%).
How's everyone else working it?
