For the dvxfest here, the export codec must be h.264 and that's for good reason since it's a good web viewing codec.
You just need to mess with the mbits per second to get the best ratio of quality to size. Also reduce your frame size and your audio khz. Audio usually is a tiny file in comparison to video but it adds up quick when making small web files. Also use a variable bit rate because it will save space when there isn't much going on in the shot.
I have been exporting with premier and it took like a month of trial and errors and testing and exporting and all that good stuff before I was able to aaa..... you know... find the sweet spots..... Hey I'll get back to you ... my wife is dragging me off the comp... we have a family event... I'll be back tomorrow!
Although Premiere is a great NLE, its encoding capabilities leave much to be desired. It's best to output uncompressed, preferably from AE, and then use a dedicated encoding program, such as Squeeze.
hi, the family event is over but I'm now at work on my break on my iPhone! and just wanted to say real quick, how the hec can you export from AE if we're talking about premier here! So your saying, export from premier! Then import to AE! then export from AE! you might as well put the video file in the washer and drier while your at it! My P2 footage won't go directly into AE. I don't know about yours. gotta get back to work, I'll be back
I edit and output with CS3, I also did a bit of testing... but only between H.264 and WMV. I'm finding that with H.264 I get better edging if that's an actual technical term, the edges don't have as much jagged edges as wmv, but the color of H.264 seems washed out, and H.264 is really causing alot of speckly noise. With WMV I get richer colors, and the noise pattern is quite different. Kind of pleasant compared to the speckled noise... So, based on my tests I've decided to use WMV for web videos, but I always try to keep the bitrate as high as possible.
the H.264 is pretty okay for me now actually. But my HVX is still noisy as hell, as I have wined about in another thread, and I guess that's just the good ol' HVX..
