Hi everyone,
here is my issue. I have burned a DVD and I noticed that the resolution is poor when on the large flatscreen at work. The color is fine, it's just that everything is soft, and almost pixelated. I know when I watch the footage when hooked up to my TV straight from in the camera, the footage looks great, with no pixelation. I know this is a compression issue of some sort. somewhere along the line I have lost resolution. I use a DVX 100a camera, I shot the footage in 30i, and transfered via firewire to avid xpress pro 5.5.1.
Here's where I feel may be a problem but I have no clue if it has anything to do with it ...(but probably)
I initially had trouble with my exports and I couldn't get my files out right. I export as a quick time reference, but when I went to watch the mov., only the file's audio was showing up and the video was black. I was told to try not clicking the "use Avid DV codec" button. This worked, and I was able to export all the footage fine. One of my questions is, am I missing out on good resolution this way? And how the hell do I get this avid codec? I tried to get it before, and I even downloaded some codecs from the avid website and put them into the avid folder, not the system folder, but still it doesn't show up, or work. Any suggestions?
Also, what is the difference between, DV 25 411, DV 50, 15:1s, and 1:1 resolutions? (these are the resolutions available to me in the media creation settings) I currently have it set to DV 25 411, but will changing this to something else improve my resolution?
I export the non DV avid codec footage to sorenson squeeze using the "large" compression, but I am not sure if there is something here I am missing, but obviously this is where my major compression is? what would be my best bet here? Now that I think about it, I don't think I used the mpeg2 button ,I just clicked the DVD NTSC large button, opened my file and squeezed it. Should I hit the mpeg2 button and adjust settings here? what would be my best bet here? I see that I can use the "custom settings" menu, and get a bunch of options,
My audio is fine by the way.
How do I find what the frame size of my project is? I think this would help? and do I set it to that? What is the "data rate", what is this? I know this is a lot of questions, but I should learn this crap. :huh: Ben
