exporting problem with avid free dv
emma
Please help me.. i am trying to export a file from free dv. the problem is that the quality and sound are good but it is skipping during play back in my quick time player.. how do i fix this.. here are my export setting i am set at now.
Quick time movie.. 720 x 486... size to fit... RGB.. file field order even... native dimensions
video : compression: none
depth: millions of collors
quality: high
sound: format: uncompressed
sample rate: 48khz
sample size: 16
channel: 2
I am trying to export to a external drive to convert into another avid program of my friends to color correct. so i can't compress it at all.. please help me i have a week dead line.. how do i stop it from skipping??
Hmmm, Avid Free DV is really limited. I'm wondering if you have a compatible version of Quicktime installed?
What are your system and software specs?
Another question,
Where are you playing back from? Are you playing back from your internal Hard Drive, an external Hard Drive, or a Data DVD.
If you are playing back from an external hard drive, how is it connected to the computer?
I am playing it back from my external hard drive it is hooked up through a usb. into quick time 7.15
The skipping playback that you describe can be caused by the drive being too slow or the processor being underpowered (as noted by DC and Gordon). It doesn't necessarily mean there's something wrong with the file. Has your friend tried importing the file into their system? Step one is to determine if there really is a problem - send a short test clip over to your friend for a test.
You could also try dropping it onto your internal, and see if that fixes it.
Which USB is your hard drive plugged into? Is it a front side port, or a rear port?
its the rear port. I am trying to get a hold of my friend to check that out waiting for an answer back from him. thank you so much for responding to me i have been very frustrated.. i will let you know when i get it imported into my friends computer and if it worked..
