Proteus said:The problem is with the Windows version of QT player. It will play it back washed out on PC whether you made it with an other app or with the QT. The same clip will look normal on Macintosh most of the times -assuming you didn't make weird levels corrections based on arbitrary windows gamma settings.
Any other gamma than 2.2 is obsolete nowadays. Most of the panels, projectors etc sold, have this gamma and tvs and dvds too. So you should calibrate your monitor so that your work looks fine on 2.2 gamma displays -to be compatible.
reflex said:Alright, Does anyone have a trick to keeping QT file sizes low? I rendered a WMV in 1440 x 1080 , 1 min 36 sec... and it came out at 95mbs... looked good and sounded clear. Then I rendered a QT the same way and it still the sound was not that great and the file size was 780mbs!!! WTF I get that all the time. like the file sizes of windows media are like 1/5th or less than a qt file. I used to have no prob, now they all just look bad, sound bad and are HUGE in size.
reflex said:Another thing though, if QT looked so bad on pc no matter what, then why doens't apple.com quicktime trailers look bad? they loook perfect...
reflex said:Alright, Does anyone have a trick to keeping QT file sizes low? ....Then I rendered a QT the same way and it still the sound was not that great and the file size was 780mbs!!! ...
James Gerber said:I don't know, but would like to know too.
I usually ended up making my video sizes for my QT files like "1/2" the size.
So if my WMV file was like 640x480, then my QT file would be like 320x240 (and lik
I've also tossed around the idea of getting full version of QT for my pc... Does it cost alot? and also will it allow me to encode files as the legendary h.264 or whatever it is?
reflex said:Your example looks really good. I downloaded the program and I could load any .avi files into it, I guess its the wrong format. Seems to be a little too technical for me. I see what you mean by the wording. Can't believe that it wont take regular avi's though...hmm maybe i'm doing something wrong.
