Exporting Footage! - Need help Fast!
DDirector
I have footage from my T2i DSLR.
I converted the video to ProRes 422. I then put it into FCP and I just dragged it into the time line, it asked if I wanted to change the video settings so I pressed 'yes'
Shot: 1080 - 24p
[MPEG Streamclip - Apple ProRes 422]
Now I need to export this in 720 24p.
And another copy in SD.
How do I do this?
Export it using QuickTime conversion. There you can set codec, frame size and frame rate as well as audio
Okay. Thanks. Last time I exported to Quick Time, not the conversion one. I just pressed option and changed some formats there, but didnt work.
Would this be good? - So I can upload it in FB, YouTube and/or Vimeo:
Export - Export to Compression
Options
Settings - H.264
................Best
................OK
Size - HD 1920x1080 16:9 (or if they want 720p) HD 1280x720p 16:9
Leave everything else as is.
Is that right? Am I making the right choice for the size too?
What about for SD?
Thanks!
Okay. Thanks.
I will give it a try in a few hours when I get back to the editing lab and give it a try. Hopefully it works this time! :D
