Hi all...please forgive the super noob question, I have ordered Barry's book but I live in China so it may be a while before i get it. So, in the interim...we're going to be shooting a lot of footage via our HMC and 60d (both use SD cards), so I bought a SD card reader to use for importing the footage.
We will be using premiere pro, ultimately, for editing, but I don't necessarily want to both importing into that at this point, I just want to pull the footage off of the SD cards and store it on the hard drive in the same format it's in on the card. Can I just copy/paste the "PRIVATE" folder (or the AVCHD folder inside it), rename the folder with logging info, and store the files that way? I assume that would work, but I don't know if it's the easiest/best/most lossless way to do it.
Also, just to test, I shot some footage with the HMC, pulled it into premiere, and hit "render all in work area" so the preview would run smoothly. It doesn't look very sharp, though; whenever I zoomed in at all there was a lot of pixellation. Even when I exported a still, it was pretty small (attached below, pixel aspect ratio is off but I wanted to upload exactly what premiere exported. Is that just a factor of Premiere pro not having done the "final" rendering or whatever yet, or do I need to be tweaking settings in the camera?
Again, forgive the noob questions, I just got the camera, switched to premiere pro, and barrys book hasn't arrived yet. Previous to this I was using a DVX, so the totally digital workflow and storage thing is new to me. Thanks!
