exporting as 16:9
sean90291
If I have a 4:3 letterbox film in my Avid, how would I export it so that the black bars were squeezed out and the whole film became 16:9 output? That is, if I want to get rid of the black bars and keep the image blown up to true 16:9, can I do that on export? Or is there another step I have to do first.
Ultimately, I want to reproduce the film on DigiBeta for projection in a theatre (having now seen my short projected at 4:3 and accidentally blown up to 16:9--even though I hadn't framed it that way--the 16:9 screening blew the 4:3 away). I think I'll have to disagree with the folks who say if you shoot 4:3 and have a great story, just exhibit 4:3. I say exhibit 16:9 AT ALL COSTS!
If you are running on a Mac, Apple's Compressor can crop out the bars and from there you can create a native 16x9 image. Not sure how to do it on a PC.
You probably want to scale the image vertically in Avid to give the correct ratio for anamorphic output. I'm sure there's an effect which does that, but I don't remember what it is.
This is VERY useful for all Avid users who have 4:3 footage. I couldn't find info on how to do it anywhere in the manuals. Seems like a common thing to try to do.
Krestofre, would this also work? Use the Reformat>Pan and Scan effect, set the Source to 1.33 and the Target to 16:9 Anamorphic.
I think that would work ... to tell you the truth I haven't messed with Pan and Scan much. I normally just throw a resize effect on. :)
Okay thanks, I'll stick with Re-size. Seems MUCH simpler. I did use re-size already in the timeline for various shots. I have never tried putting a Re-size on top of existing Re-size effects. EDIT: I guess I should collapse the video layer before I do this...so I can effectively apply the re-size on top of a re-size.
Yeah, or go back to my favorite trick of adding an empty video track and putting the effect on it. :)
I've never tried that. So the effect will then apply to the layers below it? Avid surprises me every damn day.
This thread is interesting.
There's a project I am involved which I shot in 4:3 on a PD170. As I agree with Sean to always exhibit in 16:9 ifyou can, I framed everything in 16:9 by taping the viewfinder so I could later add a mask on the Avid.
In fact that turned out better than using the PD170's own 16:9 capability, which I used on another moment of the shooting with crappy results. Never do that.
Well, that same project might become a theatrical film, shooting more stuff and then blowing up to film. The camera/s I will be using now will be Z1.
So here are my options and I would appreciate some opinions on:
1) Continue shooting in the same way with the Z1, in DV, using the same 4:3 ratio.
2) Shoot in DV but using the Z1 capability to shoot in real 16:9. Resize vertical => 133 on already shot material.
3) Shoot in HDV (which is 16:9) and uprezz the already shot DV material, cropped as 16:9 using the Resize vertical => 133 as suggested.
The uprezz I think will be necessary to improve on the already shot DV quality.
What do you think?
If you shoot DV and intend to alter it's aspect ratio later on, you should adjust the camera's sharpness ( detail on DVX ) down as far as it goes, and shoot 'soft'. ( This simply means you are not ADDING artificial sharpness - your not actually adding any softness ! )
Shoot full 4:3 rather than 4:3 with black bars to mask to 16:9. Shooting with the camera recording Black Bars puts ZeroBlack in your shot - regardless of exposure, so in later colour correction they set a trace on your scopes - ( not that I'VE ever been caught out that way . . . er, . . well . . . ).
After Aspect Ratio Conversion - put the sharpness you didn't add in camera back on. Voila ! nicer edges.
