Why do you have to convert the files when CS4 offers native XDCAM EX timelines in Premiere?
With all the problems I've been reading about playing HD footage on a PC, the last thing I would expect is that it would work. Well it works great on my NOT so fast PC. The 720p tests play perfectly, and the 1080p files are almost perfect. Can't wait till the i7 arrives next week. Should be like a rocket. I'm sure I will have a few more questions.
I have CS3 and even though it shows XDCAM presets it doesn't handle the proprietary MP4 files from the camera. Does CS4 handle the Sony MP4s?
I apologize for not checking his software if that has changed.
Patssle: Everything is going smooth so far. My next new ground is exporting the project for playback at a convention. I tested media exports to a number of different files and Uncompressed Avi. seems the closest to the original footage and plays back smoothly on my system. What's the best way to deliver the job for a clean HQ presentation. I will not have as much control over it once it leaves my computer? Any more good suggestions?
So CS4 does play back the EX3 files natively? No need to convert?
For presentation, I'm assuming you're playing back from a computer? It really depends on the computer used. Does it have Quicktime, or is it a Mac?
If it's just a computer hooked up to a projector, make several encoded files. A Quicktime, WMV, Flash - that way you are covered. Uncompressed isn't a good delivery format.
Yes the original EX3 1080p files imported normally
Great to hear, thanks! Considering an HVX to EX1R upgrade.
Lets have the specs of your new PC?
I am buying a new desktop next year to take advantage of Windows 7 and lots of RAM.
RAM, HD etc
Here is what I just picked up. Of course I wanted more, but it was all the cash I had in my pocket today. I'm still going to run my Widows XP Pro 64 bit and can change later, but this will get me where I have to go this month. I'll let you know how it works out after I test it, but it looks impressive even before I power it up.
ASUS P6TD DELUXE 1366 Motherboard
INTEL CORE i7-920 2.66GHz
ASUS EAH 4870 DK 1gig VGA
CORSAIR 3GB . 3 X 1GB DDR3
i-CUTE Casing / ENLITE 750W Sniper Power
2x 250GB SATA System HDs (I always set up a clone system HD backup)
If I had more cash I surely would have spent it. It has 3 more memory slots so I can add 3x 2GB CORSAIR which will give me 9 gigs of Ram to top it off.
If You Smelllllllllllll What The Rock Is Cookin'
Nice one....I will be interested to hear your comparisons with the old system.
Maybe some comparison tests with rendering?
Good luck with it and I hear you about wanting/spending more if you could.
