As already stated on many web sites you may use ExpressCard/34 SDHC adapters in USB mode for the Sony PMW EX1/EX3.
There are mentioned a couple of express adapters and SDHC cards supposed to work flawlessly within a EX1/EX3. In the meantime lots of them became unavailable (especially in europe) and some other web shops sell 'special' EX1/EX3 adapters from 80€ up to 100€.
Well, what's so special about these adapters? What do they have in common?
To find out what's inside I bought a couple of them and opened the cover by simply stretching it a little bit and pulling it aside.
All of the known working adapters use the same chip GL827 by Genesys Logic (http://www.genesyslogic.com/_en/product_01_1.php?id=26). Unfortunately the presence of a GL827 is not sufficient to make the EX1/EX3 correctly recognise the adapter.
So I got the cheapest adapter available from ebay member exgrass called 'ExpressCard/34 Express Card Karte Reader xD/SDHC/SD/MMC' for 9€ and found a GL827 not working with EX1/EX3. The next step was to find out what's the difference to a working adapter?
Finally I found out it's just one pin that was connected wrong for some reason: An express card can identify itself as a USB and/or a PCIe device. For some reason this adapter had pin 17 of the express slot connected which makes the card also a PCIe device. After cutting the connection on the PCB the card got recognized as smoothly as any other working adapter.
As I do not have any of the highly recommended but expensive SDHC cards I inserted a low cost one called PLATINUM class 6 bought last month for about 22€. After pressing the record button on the camera it worked like a charm. No media errors - just as any other *xS solution.
Here you can find some pictures attached that show the express card 'surgery'. As you can see both SDHC cards need to be shaved a little bit to fit into the card slot completely - otherwise it is not possible to close the card slot door.
Summary: The EX1/EX3 is not so picky about what you connect as a mass storage device via USB. It does not matter if it is a GL827 based card reader, an USB-IDE/SATA adapter or simply an USB stick (see my other posting).
Deti
Deti
