EX1 1080 50i shutter
dreamlx
Hi,
Normally I would use a shutter of 50 for shooting 50i. However on the EX1 60 seems to be the lowest speed you can set. I have made some tests and at 100, the EX1 seems to be noisier than the Z7 at low light, so I went to 60. Which shutter speed do you recommend and use for shooting 50i ?
Also concerning white balance, it seems like the only way to emulate the daylight and artificial light settings found on the Z7 is the define to picture profiles and set the color temperature manually, is this correct ?
Thanks in advance
