When I mount my 35mm adapter to the front element of my EX-1 lens, I need to calibrate focus first, and then adjust the CAMERA's zoom so that the image fills the frame. If I don't adjust the Camera's zoom, I run the risk of vignetting.
My question is, once I've found the sweet spot and mark the zoom barrel, can I zoom in further if I wish--in effect using the camera's zoom as a tele-extender--and if so, to what extent. Will I have image degradation if I do? Or should I just leave it on the sweet spot, and treat it as a fixed focal length lens.
For example, when I have a 50mm prime mounted on the adapter, the EX-1's zoom is set to about 40mm to fill the frame. If the zoom is set wider, I get vignetting. Zoom tighter--to say 80m--and I am in effect changing the mounted lens' focal length, making it longer. I wonder if there is perceptible image degradation.
I am new to video, so judging whether or not there is degradation, is not easy for my eye to see but I wonder what others think and have observed.
Thanks in advance for your help.
Cheers,
-Emile
Cheers,
-Emile
