EVF for Panasonic AF100 shooting 23.98
madman1
Hey folks. I have a zacuto evf pro and cannot use it when shooting Psf (23.98) on the AF100. The camera shuts down the hdmi output when you switch on
Psf to get 23.98. Does anyone know of a bypass - hdmi to rca to use the camera's composite out? Or is there another EVF out there that has composite in. Cineroid? DP4? if anyone has done this, what does the output look like?
I guess what I'm saying is I want to bypass the hdmi ouput(since it's no there) and still use an EVF.
Thanks in advance!!
Thanks dustylense. Sorry, I should have mentioned that I'm shooting to a Ki Pro Mini. Without the Psf on, I get 29.97 instead of 23.98 and the Zacuto works brilliantly. So I'm using the sdi out to record to the Ki Pro. The hdmi port is on when shooting to 29.97 but to get 24p, Psf on the camera must be turned on. Once you turn Psf on, the camera shuts down the hdmi port. This has been well documented. I've gone through my own tests to confirm this. Or am I missing something - doing something wrong?
I've tried this and still no joy. As soon as the Psf menu in the camera is on, I can't get the Zacuto to work either from the camera or the Ki Pro Mini. If I stick with 29.97, the Zacuto works. I wonder if I have a setting wrong. Or maybe the Zacuto doesn't see 24p? Do you have the same rig?
