Event Alp5 speakers: $200 Great condition. Barely used. Includes original box, power cables and manual.
[TABLE="width: 630"]
[TR]
[TD]The ALP 5 is a time and phase corrected biamplified monitor that redefines excellence in small-footprint studio reference systems. They deliver a sound that's much wider, much deeper, much more defined, and packed with much more low-end punch than mere mortal direct field monitors.[/TD]
[TD]
[/TD]
[/TR]
[/TABLE]
Active Linear Phase Specifications
Low Frequency Driver
5.25” magnetically shielded mineral-filled polypropylene cone with high temperature voice coil and damped rubber surround.
High Frequency Driver
1” magnetically shielded natural soft dome neodymium with ferrofluid-cooled voice coil.
Frequency Response
45Hz – 39kHz; 53Hz – 19kHz, ±3dB, Ref 500Hz.
Crossover
2.6kHz active second-order asymmetrical
_Studio Precision Specifications (cont.) Sound Pressure Level (Output)
>105dB
Noise
>100dB below full output, 20kHz bandwidth, unweighted
Input Connectors
XLR and 1/4” connectors; accept balanced or unbalanced sources RCA connector; accepts unbalanced sources
Polarity
Positive signal at + input produces outward low frequency cone displacement
Input Impedance
40kΩ balanced, 20kΩ unbalanced
Input Sensitivity
0.5V RMS input at the balanced ins or 0.25V RMS input at the unbalanced in produces full output with Input Sensitivity control at maximum.
Input Sensitivity control range
20dB
Protection
RF interference, output current limiting, over temperature, turn-on/off transient, subsonic filter, internal mains fuse.
Indicators
Power ON LED indicator.
Power Requirements
40VA, factory programmed for either 100V~ 50-60Hz, 120V~ 60Hz, 220~ 50Hz, 240V~ 50Hz mains.
Cabinet
5/8” vinyl-laminated MDF, internally insulated.
Dimensions
7.5” W x 10.5” H x 9” D
Weight
11.95 lds each.
[TR]
[TD]
[/TR]
[/TABLE]
Frequency Response
Crossover
>105dB
Noise
Input Connectors
Polarity
Input Impedance
Input Sensitivity
20dB
Protection
Indicators
Power Requirements
Cabinet
Dimensions
Weight
11.95 lds each.
