EVA1 ROP Playback question
OnSet
I have a shoot coming up where I'll have an EVA1 high on a jib doing a master overhead shot of some dancers. I figured the ROP would be a good way to roll/cut.
But today took a look to try to test controlling playback with the ROP - and couldn't figure it out. The Rec Chk button in the ROP produces an 'invalid' on the VF screen. I couldn't figure out how to get the thumbnails, and even worse, when the ROP is connected the Thumbnails button on the camera seems to be disabled. So in order to do playback I have to kill the ROP and do it manually from the camera (which is a real pain when the camera is way up in the air...)
Has anyone done this? Am I missing the easy solution?
Thanks!
Also - suggestion -- it would be really helpful if ROP would display the functions of the various function buttons!
I asked the same question in the FB user group. No image. It's a control panel only.
Most simple solution would probably be an external recorder via SDI/HDMI on a long cable and have the playback there.
btw.. what about the scene file improvement? How did it work?
Not trying to get an image in the ROP. Current plan is that Camera will be sending both SDI and HDMI back from its position for monitoring. (SDI will go into a quad split, HDMI will go into a solo monitor.) The issue I'm having is that I can't figure out how to do any kind of playback from the camera while the ROP is connected. I saw that previous ROP versions seemed to have thumbnail options. I was hoping that I could verify/check playback from the camera without having to bring the jib down and disable the ROP wifi connection.
In the meantime I set one of the user buttons on 'Rec Check' -- If I press the button I get "INVALID" on the screen. Is this something I might have turned off somewhere???
In terms of color, last couple of shoots the scene file was set like this... Most of the changes are pretty minor, but the clients were happy.
Gamma V-255570L1
M. Ped -6
Detail ON Level -4 Freq 1
Chroma Level 3%
Color SW ON
R Sat -2
Yl Sat -1
ah, sorry, I got this wrong. No idea so far.
Many thanks for the scene file settings. I will give it a try and report back.
I must admit that I have not tried playing back files using the ROP. I don't have gear handy at the moment. I suggest you contact our Service Support line and our engineers can work to get you the answer.
Gamma V-255570L1
M. Ped -6
Chroma Level 3%
Color SW ON
R Sat -2
Yl Sat -1
looks great, many thanks for sharing!
After a first test I went with M. Ped to -2 instead of -6. The difference is very subtle though.
It turns out that the reason Rec Check wasn't working is that I had the camera on Simul record. Rec Check works ok on Relay and Off record modes.
(Which didn't really solve my problem of wanting to access the thumbnails menu from the ROP - but it did straighten out one issue...)
Recording to a Shogun is about the only solution I can think of, then you have all your playback right at your fingertips.
Yes, I may need to... Already have more than one external recorder on the shoot -- was trying to eliminate extra wiring and keep things simpler. (It's already a multi-camera shoot with director's monitor on a quad split and clients with 2-3 monitor stations, selectable to Quad or single camera.) Also the confidence factor of being able to check playback of the card(s) directly from the camera.
