Roberto Tafuro
Hallo to everybody! I have a question for you: is there anybody that have changed the american scene files to european? I usually type the numbers in the scene files, but now i'm lazy and i want to load different scene files with SD. Before i start doing this i want to ask you if i have only to replace this FRAME RATE: 24 FRAME with this FRAME RATE: 25 FRAME and this SYSTEM FREQ:59.94Hz to this SYSTEM FREQ:50.00Hz or i have to do something else. Another question is this : in the CINEG scene file for ex the variable frame rate is on, so it means that i've to use the 720p mode, but what happens if i select the 1080p mode? The scene file will be load or not? And the last one : when i load the scene files it will load all the setups (24fps,12fps and so on ) or i can choose the scene file fps?
Thank you for the support!
Bests,
Roberto
Bests,
Roberto
