joe12south
I would amend this to state...
- Shoot with a camera profile that matches your subject and lighting range
Cine-D and V-log profiles are great for high contrast subjects or contrasty light.
The Natural profile is great for normal contrast subjects under medium contrast light.
The Standard and Cine-V profiles are great for low contrast subjects and low contrast light.
*** Choose the profile that matches your subject and lighting ***
You can shoot everything with V-log but you may not be gaining much when you don't need the full 12 F-stops of DR.
I think you've said you'll be recording internally, right? If that's the case, and given the style of shooting you describe, I do agree than Cine-D is going to be your "go to" profile if you then want to massage it in post. *Don't* slam all of the settings to -5 in an effort to get "flat." Don't mess around with highlights, shadows, any of the "i" settings. That's a recipe for post-production pain, and will net you 0% extra range. Paul Leeming's recommended settings are a great starting point. Apply his Leeming One LUT after the fact, and you've got a good, solid, accurate starting point for creative grading. It's an 8-bit image, so there is only so far you can push it, but generally it can survive some decent pushing and pulling.
I know some people are going to sneer at this suggestion, but I also think you should evaluate FilmConvert. I often use it (dialed-down) for a final finishing pass on my completed project to tie everything together and take some of the edge off.
