FS5: Error FS5 raw with new firmwire inferno 8.11
I test new firmwire Inferno 8.11 with FS5 RAW but Inferno can't record with new firmwire 8.11 monitor Inferno just blink Red
but before update with firmwire 8.1 its no problem, i use drive Sandisk Extreme Pro SSD 240GB, and i test with sony 7s i have same problem cant record
Record with FS5 RAW
Record Manual with FS5 RAW
[video=https://www.youtube.com/watch?v=-Hc2aJx0ZDc&feature=youtu.be[/video]
Did you try downgrade? I still have somewhere 8.01 for that case.
But my Inferno works with fs700 without problems.
i dont have file firmwire 8.01 did you have? i searching in google file is missing.. by the way you use new firmwire in fs700
i have problem again firmwire 8.01 in my inferno cant not out signal video from sdi or hdmi setting camera is RAW FS5
if i setting XAVC from FS5 signal out sdi or hdmi from inferno its ok no problem
its now working i reinstal firmwire 8.11
and now problem signal video from SDI RAW inferno in my external monitor Blackmagic Video Assist 5 inch in display like a double picture (attach in photo) and try to my monitor type ViewZ VZ-185PM-P is blank (no signal)
but when i change camera setting XAVC (Not RAW) its working
Double picture (offset vertically or horizontally) usually means bad SDI cable!
Piotr
hi piotr..
picture horizontal in display monitor blackmagic 5'
From Inverno to Blackmagic monitor 5' i use SDI Canare L-2.5CHD, Canare BNC to DIN and from Inverno to ViewZ monitor i use cable SDI Canare L-4CHD, Canare BNC to BNC
Piotr tried to say that you cable is bad - not good quality, damaged etc. You should try different cable.
hi kroncaX.. its imposible if my cable damaged, because when i change record setting XAVC in my camra its good signal out SDI/HDMI from inverno
